Easily convert kVA to kW with our free online calculator. Learn the kVA to kW formula, understand the role of Power Factor, and use our quick reference conversion table.
How to Convert kVA to kW
To convert Kilovolt-Amps (kVA) to Kilowatts (kW), you simply multiply the apparent power by the power factor of the system. While kVA represents the total power supplied to a circuit, kW represents the actual power that performs work.
The Formula
The relationship between kVA and kW is governed by the efficiency of the electrical system, known as the Power Factor (PF):
kW = kVA × Power Factor (PF)
For most industrial applications and generators, a standard Power Factor of 0.8 is assumed if the specific rating of the equipment is unknown.
kVA to kW Conversion Table
This reference table shows common kVA ratings converted to kW using a standard 0.8 Power Factor.
| Apparent Power (kVA) | Real Power (kW) @ 0.8 PF |
| 1 kVA | 0.8 kW |
| 5 kVA | 4.0 kW |
| 10 kVA | 8.0 kW |
| 25 kVA | 20.0 kW |
| 50 kVA | 40.0 kW |
| 100 kVA | 80.0 kW |
Contextual Information
kVA (Apparent Power) vs. kW (Real Power)
Think of kVA like a glass of beer. The total volume of the glass (including the foam) is the kVA. The actual liquid beer that you drink is the kW. The foam represents the reactive power (kVAR) which is necessary to maintain the electrical field but doesn’t do “work.”
The Importance of Power Factor (PF)
The Power Factor is a decimal between 0 and 1.
- A PF of 1.0 (unity) means the system is perfectly efficient, where all supplied kVA is converted into kW (common in purely resistive loads like heaters).
- A PF of 0.8 is common for inductive loads like electric motors and industrial machinery.
Why use this converter?
This conversion is vital for sizing backup generators, UPS systems, and transformers. Generators are typically rated in kVA, but appliances and tools are rated in Watts or kW. Using this tool ensures that your power source has enough “real power” capacity to handle the electrical load of your equipment without overloading.
