Milligram/Liter to Kilogram/Cubic Meter (mg/L to kg/m ³) Converter
Quickly convert density from Milligrams per liter (mg/L) to Kilograms per cubic meter ( kg/m ³). Free online calculator with the conversion formula, reference table, and technical definitions.
Density Converter
The mg/L to kg/m³ Conversion Formula
Converting density or concentration from Milligrams per liter (mg/L) to Kilograms per cubic meter (kg/m³) is a common task in water treatment, environmental science, and chemistry. Because the metric system is based on powers of ten, the conversion factor is exactly 1,000.
The mathematical formula:
kg/m³ = mg/L ÷ 1,000
Step-by-Step Mathematical Logic:
  • Mass: 1,000,000 Milligrams (mg) = 1 Kilogram (kg).
  • Volume: 1,000 Liters (L) = 1 Cubic Meter (m³).
  • Combined: Since you are dividing mass by volume, the conversion factors simplify so that 1,000 mg/L equals 1 kg/m³.
Quick Reference Conversion Table
Milligram/liter (mg/L)Kilogram/cubic meter (kg/m³)
1 mg/L0.001 kg/m³
100 mg/L0.1 kg/m³
1,000 mg/L1 kg/m³
10,000 mg/L10 kg/m³
1,000,000 mg/L (Density of Water)1,000 kg/m³
Contextual Information
What is a Milligram per Liter (mg/L)?
The unit mg/L is most frequently used to measure the concentration of a substance (solute) dissolved in a liquid. In many water quality contexts, 1 mg/L is approximately equal to 1 part per million (ppm) because a liter of water weighs roughly one million milligrams.
What is a Kilogram per Cubic Meter (kg/m³)?
The kg/m³ is the official SI derived unit for density. It represents the mass of a substance that occupies one cubic meter of space. It is the standard unit for large-scale engineering calculations and for describing the density of solids, liquids, and gases in industrial environments.
Why is this conversion important?
Engineers often need to convert laboratory-scale concentration results (mg/L) into bulk density figures (kg/m³) to calculate total weight for industrial chemical dosing, environmental impact modeling, or designing filtration systems for large reservoirs.
