MJ to kWh Converter
Quickly convert Megajoules (MJ) to Kilowatt-hours (kWh) with our free tool. Includes the MJ to kWh formula, energy conversion tables, and real-world examples.
Energy Converter
How to Convert Megajoules to Kilowatt-hours
Both Megajoules (MJ) and Kilowatt-hours (kWh) are units used to measure energy. While kWh is the most common unit for electrical energy usage on residential bills, MJ is often used in scientific contexts and for measuring the energy content of fuels like natural gas.
The MJ to kWh Formula
The conversion is based on the definition that 1 Watt is equal to 1 Joule per second. Therefore, 1 kWh (which is 1,000 Watts for 3,600 seconds) equals exactly 3.6 Million Joules. To convert MJ to kWh, you divide the value by 3.6:
Kilowatt-hours (kWh) = Megajoules (MJ) ÷ 3.6
MJ to kWh Quick Reference Table
This table shows common energy values converted from Megajoules to Kilowatt-hours:
Megajoules (MJ)Kilowatt-hours (kWh)
1 MJ0.2778 kWh
3.6 MJ1.0000 kWh
10 MJ2.7778 kWh
50 MJ13.8889 kWh
100 MJ27.7778 kWh
500 MJ138.8889 kWh
Context: Why Convert MJ to kWh?
Understanding the relationship between these units is crucial for comparing different energy sources:
  • Natural Gas Billing: In many regions, natural gas usage is measured in MJ by the meter, but consumers may want to compare that cost to their electricity usage, which is priced in kWh.
  • Renewable Energy: Solar panels produce energy measured in kWh, but the total solar radiation hitting a surface is often measured in MJ per square meter.
  • Engineering Specs: Battery capacities are often discussed in Joules/Megajoules when looking at rapid discharge rates, while day-to-day capacity is rated in kWh.
Why Use This Converter?
Energy units often involve factors of 3.6 or 3,600, which are non-intuitive to calculate mentally. This tool provides an instant, high-precision conversion, ensuring that your energy audit, school project, or utility bill comparison is accurate to the decimal point.
