Quickly convert Siemens/meter (S/m) to Mho/meter (℧/m). Learn why these conductivity units are identical and explore the history of SI electrical units.
Conductivity Converter
The Conversion Formula
Converting Siemens/meter (S/m) to Mho/meter (℧/m) is a direct identity conversion. Both units measure electrical conductivity with the exact same magnitude. The numerical value remains unchanged during the transition.
1 Siemens/meter (S/m) = 1 Mho/meter (℧/m)
Quick Reference Table
| Siemens/meter (S/m) | Mho/meter (℧/m) |
| 1 S/m | 1 ℧/m |
| 0.5 S/m | 0.5 ℧/m |
| 100 S/m | 100 ℧/m |
| 0.001 S/m | 0.001 ℧/m |
Contextual Information
What is Siemens/meter?
The Siemens/meter (S/m) is the International System of Units (SI) standard for electrical conductivity. It measures the ability of a material to allow the flow of electric current. It is named after the German industrialist Werner von Siemens and was officially adopted in 1971 to provide a standardized SI unit for conductance and conductivity.
What is Mho/meter?
Mho/meter (℧/m) is a non-SI unit for conductivity that was common in the early 20th century. The name "Mho" is "Ohm" spelled backward, a clever way to show that conductance is the reciprocal of resistance. While it is still found in historical engineering documents and older textbooks, it has been largely superseded by the Siemens in modern scientific literature.
Historical and Practical Use
Because the ratio is exactly 1:1, there is no risk of mathematical error when swapping these terms. However, using Siemens/meter is preferred in professional engineering reports, international standards (ISO), and academic research to ensure compliance with modern SI conventions. This converter helps users confirm that their data remains accurate when moving between older source materials and modern requirements.
