Convert Volt-Amps (VA) to Kilowatts (kW) instantly with our free online calculator. Learn the VA to kW formula and the importance of Power Factor in electrical systems.
How to Convert Volt-Amps (VA) to Kilowatts (kW)
To convert Volt-Amps (VA) to Kilowatts (kW), you must multiply the apparent power (VA) by the power factor (PF) of the electrical load and then divide by 1,000. This calculation is vital because it translates the total power circulating in a circuit (apparent power) into the actual power used to perform work (real power).
The Formula
The standard mathematical equation used in our calculator is:
kW = (VA × Power Factor) ÷ 1,000
If the power factor is unknown, a standard Power Factor of 0.8 is typically used for general industrial equipment, while purely resistive loads (like heaters) have a PF of 1.0.
VA to kW Quick Reference Table
This table shows common VA ratings converted to kW using a standard 0.8 Power Factor:
| Apparent Power (VA) | Real Power (kW) @ 0.8 PF |
| 500 VA | 0.4 kW |
| 1,000 VA (1 kVA) | 0.8 kW |
| 2,500 VA | 2.0 kW |
| 5,000 VA (5 kVA) | 4.0 kW |
| 10,000 VA (10 kVA) | 8.0 kW |
Contextual Information
Understanding VA vs. kW
- VA (Volt-Amps): This is “Apparent Power.” It is the product of voltage and current in a circuit. It represents the total load that the wiring and electrical source (like a generator) must be able to support.
- kW (Kilowatts): This is “Real Power” or active power. It is the actual energy that is converted into heat, light, or mechanical motion.
The Power Factor (PF) Explained
The Power Factor is a ratio (ranging from 0 to 1) that represents the efficiency of the electrical power being used. Inductive loads, such as electric motors and transformers, require “reactive power” to maintain their magnetic fields. This reactive power does not do work but adds to the VA rating. The closer the Power Factor is to 1.0, the more efficiently the system is converting VA into usable kW.
Why use this converter?
Most Uninterruptible Power Supplies (UPS) and transformers are rated in VA or kVA. However, the equipment you want to plug into them (like servers, computers, or tools) often lists their power requirements in Watts or kW. Using this converter ensures you don’t overload your power supply by accurately calculating the real-world power capacity based on your system’s efficiency.
