WARNING 36 Mains Failure fault in Danfoss FC301 drive
Cause: This warning/alarm is only active if the supply voltage to the drive is lost and parameter 14-10 Mains Failure is not set to [0] No function.
Troubleshooting:
– Check the fuses to the drive and mains supply to the unit.
