Convert Farad (F) to Centifarad (cF) instantly. This free tool includes the F to cF formula, a quick reference table, and scientific context for capacitance units.
Farad to Centifarad Converter
Conversion Factor: 1 Farad = 100 Centifarads
Farad to Centifarad Conversion Formula
To convert Farads (F) to Centifarads (cF), the capacitance value is multiplied by 100. The mathematical expression is as follows:
Centifarad (cF) = Farad (F) x 100
Because the centi prefix signifies one-hundredth of the base unit, it takes exactly one hundred centifarads to equal one Farad.
Farad to Centifarad Conversion Table
This quick reference table helps you convert common Farad measurements into Centifarads:
| Farad (F) | Centifarad (cF) |
| 0.01 F | 1 cF |
| 0.1 F | 10 cF |
| 0.5 F | 50 cF |
| 1 F | 100 cF |
| 10 F | 1,000 cF |
| 100 F | 10,000 cF |
Understanding the Magnitude
The Farad (F)
The Farad is the base unit of electrical capacitance in the International System of Units (SI). Named after Michael Faraday, it measures the capacity of a conductor to store an electric charge. In the world of practical electronics, a Farad is considered a massive unit; most capacitors used in circuit boards are measured in microfarads (uF) or nanofarads (nF).
The Centifarad (cF)
The Centifarad is a submultiple of the Farad. The prefix centi stands for one-hundredth (10 to the power of -2). Therefore, a Centifarad is 0.01 Farads. While units like centimeters are incredibly common for length, the centifarad is used less frequently in consumer electronics than other SI prefixes. It is, however, a standard unit used in physics classrooms and specific industrial capacitance studies.
Practical Application
Converting Farads to Centifarads is a simple matter of shifting the decimal point two places to the right. This converter is particularly useful when analyzing high-capacity components such as large electrolytic capacitors or small supercapacitors where the capacitance is close to the base SI unit. Using an automated tool ensures precision and prevents simple errors in technical documentation.
