Quickly convert Centifarads (cF) to Farads (F). Includes the conversion formula, a quick reference table, and scientific context for SI capacitance units.
Centifarad to Farad Converter
1 Centifarad (cF) = 0.01 Farads (F)
The Centifarad to Farad Formula
To convert from Centifarads (cF) to Farads (F), you multiply the capacitance value by 0.01 (or divide by 100). The mathematical formula is:
Farad (F) = Centifarad (cF) x 0.01
This means that one Centifarad is equal to one-hundredth of a Farad. This conversion follows the standard metric prefix system where “centi” denotes a factor of 10 to the power of -2.
Centifarad to Farad Conversion Table
Use this quick reference table for common Centifarad to Farad conversions:
| Centifarad (cF) | Farad (F) |
| 1 cF | 0.01 F |
| 10 cF | 0.1 F |
| 50 cF | 0.5 F |
| 100 cF | 1 F |
| 1,000 cF | 10 F |
Understanding the Magnitude
What is a Centifarad?
The Centifarad (cF) is a submultiple of the Farad. In the International System of Units (SI), the prefix “centi” denotes a factor of one-hundredth. While centi- units are very common for length (centimeters), they are rarely used in practical electrical engineering for capacitance, where microfarads and picofarads are the industry standard. However, it remains a technically valid SI unit.
What is a Farad?
The Farad (F) is the base SI unit of capacitance, named in honor of Michael Faraday. It measures the ability of a body to store an electrical charge. A capacitor has a capacitance of one Farad when one Coulomb of charge causes a potential difference of one Volt across its plates.
Practical Application
In the world of electronics, a Centifarad is actually a significant amount of capacitance. You are more likely to encounter measurements in this range when dealing with large electrolytic capacitors or small supercapacitors. This converter simplifies the scaling process by moving the decimal point two places to the left, ensuring accuracy in your technical documents and physics calculations.
