Farad to Decifarad Converter
Convert Farad (F) to Decifarad (dF) instantly. This free tool includes the F to dF formula, a quick reference table, and scientific context for capacitance units.
Conversion Factor: 1 Farad = 10 Decifarads
Farad to Decifarad Conversion Formula
To convert Farads (F) to Decifarads (dF), the capacitance value is multiplied by 10. The mathematical expression is as follows:
Decifarad (dF) = Farad (F) x 10
Because the “deci” prefix signifies one-tenth of the base unit, there are exactly ten decifarads in every one Farad.
Farad to Decifarad Conversion Table
This quick reference table helps you convert common Farad measurements into Decifarads:
Farad (F)Decifarad (dF)
0.1 F1 dF
0.5 F5 dF
1 F10 dF
5 F50 dF
10 F100 dF
100 F1,000 dF
Understanding the Magnitude
The Farad (F)
The Farad is the base unit of electrical capacitance in the International System of Units (SI). Named after Michael Faraday, it measures the capacity of a conductor to store an electric charge. One Farad is a very large amount of capacitance; for context, most capacitors used in modern electronics are sized in microfarads (one-millionth of a Farad).
The Decifarad (dF)
The Decifarad is a submultiple of the Farad. The prefix “deci” stands for one-tenth (10 to the power of -1). Therefore, a Decifarad is 0.1 Farads. While not as common in consumer electronics as the microfarad, the Decifarad is a standard SI unit used in specific scientific calculations and laboratory settings where capacitance values are relatively high.
Practical Application
Converting Farads to Decifarads is a simple matter of shifting the decimal point one place to the right. This is useful when working with high-capacity storage components or supercapacitors that are nearing a full Farad in capacity. Using an automated converter ensures the accuracy of your technical documentation and prevents simple calculation errors.
