Instantly convert Farads (F) to Microfarads (uF). This free tool includes the F to uF formula, a quick reference table, and scientific context for capacitance units.
Farad to Microfarad Converter
Conversion Factor: 1 Farad = 1,000,000 Microfarads
Farad to Microfarad Conversion Formula
To convert Farads (F) to Microfarads (uF), the capacitance value is multiplied by 1,000,000. The mathematical expression is as follows:
Microfarad (uF) = Farad (F) x 1,000,000
Because the micro prefix signifies one-millionth of the base unit, it takes exactly one million microfarads to equal one Farad. This relationship is often written in scientific notation as 10 to the power of 6.
Farad to Microfarad Conversion Table
This quick reference table helps you convert common Farad measurements into Microfarads:
| Farad (F) | Microfarad (uF) |
| 0.000001 F | 1 uF |
| 0.0001 F | 100 uF |
| 0.001 F | 1,000 uF |
| 0.1 F | 100,000 uF |
| 1 F | 1,000,000 uF |
| 10 F | 10,000,000 uF |
Understanding the Magnitude
The Farad (F)
The Farad is the base unit of electrical capacitance in the International System of Units (SI), named after the English scientist Michael Faraday. One Farad is defined as the capacitance across which a potential difference of one Volt results in a charge of one Coulomb. In practical electronics, a Farad is a massive unit; for most circuits, a 1 Farad capacitor would be physically quite large.
The Microfarad (uF)
The Microfarad is the most commonly used submultiple of the Farad in everyday electronics. The prefix micro stands for one-millionth (10 to the power of -6). Therefore, a Microfarad is 0.000001 Farads. Almost all electrolytic and ceramic capacitors used in power supplies, audio equipment, and computers are rated in microfarads.
Practical Application
When solving physics problems or using circuit simulation software, you may need to enter capacitance in the base unit (Farads), even though your physical components are labeled in microfarads. Conversely, when designing a circuit, you might calculate a need for 0.00047 Farads and need to convert that to 470 uF to buy the correct part. This converter ensures that you can shift between these scales accurately by moving the decimal point six places to the right.
