Microfarad to Farad Converter
Quickly convert Microfarads (uF) to Farads (F). Includes the uF to F formula, a quick reference conversion table, and scientific context on capacitance units.
Capacitance Converter
Conversion Factor:
1 Farad = 1,000,000 Microfarads
1 Microfarad = 0.000001 Farads
The Microfarad to Farad Formula
To convert from Microfarads (uF) to Farads (F), you multiply the capacitance value by 0.000001 (or divide by 1,000,000). The mathematical formula is:
Farad (F) = Microfarad (uF) x 10-6
This means that one Microfarad is equal to one-millionth of a Farad. This conversion is the industry standard for specifying capacitors in power supplies, filters, and timing circuits.
Microfarad to Farad Conversion Table
Use this quick reference table for common Microfarad to Farad conversions:
Microfarad (uF)Farad (F)
1 uF0.000001 F
10 uF0.00001 F
100 uF0.0001 F
1,000 uF0.001 F
10,000 uF0.01 F
100,000 uF0.1 F
Understanding the Magnitude
What is a Microfarad?
The Microfarad (uF) is a submultiple of the Farad. In the International System of Units (SI), the prefix “micro” denotes a factor of 10 to the power of -6. Because a Farad is such a massive unit of storage, almost all real-world capacitors used in circuit design—from small ceramic discs to large electrolytic cans—are measured in microfarads.
What is a Farad?
The Farad (F) is the base SI unit of capacitance, named in honor of Michael Faraday. It measures the ability of a body to store an electrical charge. A capacitor has a capacitance of one Farad when one Coulomb of charge causes a potential difference of one Volt across its plates. While you rarely find a single capacitor rated at 1 Farad in small devices, they are used in high-power audio systems and as memory backups.
Why is this conversion important?
Engineers often work with Microfarads when selecting components, but physics equations and circuit simulation software frequently require the input to be in base Farads. Shifting the decimal point six places to the left manually is prone to error; this converter automates the process to ensure the accuracy of your electrical engineering projects.
