Convert Farad (F) to Millifarad (mF) instantly. This free tool includes the F to mF formula, a quick reference table, and scientific context for capacitance units.
Farad to Millifarad Converter
Conversion Factor: 1 Farad = 1,000 Millifarads
Farad to Millifarad Conversion Formula
To convert Farads (F) to Millifarads (mF), the capacitance value is multiplied by 1,000. The mathematical expression is as follows:
Millifarad (mF) = Farad (F) x 1,000
Because the milli prefix signifies one-thousandth of the base unit, it takes exactly one thousand millifarads to equal one Farad.
Farad to Millifarad Conversion Table
This quick reference table helps you convert common Farad measurements into Millifarads:
| Farad (F) | Millifarad (mF) |
| 0.001 F | 1 mF |
| 0.01 F | 10 mF |
| 0.1 F | 100 mF |
| 1 F | 1,000 mF |
| 5 F | 5,000 mF |
| 10 F | 10,000 mF |
Understanding the Magnitude
The Farad (F)
The Farad is the base unit of electrical capacitance in the International System of Units (SI). Named after Michael Faraday, it measures the capacity of a conductor to store an electric charge. In practical electronics, a Farad is a very large unit. While most capacitors in smaller circuits are measured in microfarads (uF), larger energy storage devices and supercapacitors are often measured in Farads.
The Millifarad (mF)
The Millifarad is a submultiple of the Farad. The prefix milli stands for one-thousandth (10 to the power of -3). Therefore, a Millifarad is 0.001 Farads. This unit is frequently used in power supply filtering and audio engineering to describe large electrolytic capacitors that are too big for microfarad ratings but smaller than a full Farad.
Practical Application
Converting Farads to Millifarads is a matter of shifting the decimal point three places to the right. This converter is particularly useful when analyzing high-capacity power systems or supercapacitors where the capacitance values bridge the gap between base SI units and their submultiples. Using an automated tool ensures precision and prevents simple calculation errors in your technical documentation.
