Fault 5080 in ABB ACS880 Drive Troubleshooting
Fault 5080 in ABB ACS880 Drive Troubleshooting – Getting a Fault 5080 on your ABB ACS880 drive? Learn why the “Fan Stuck or Disconnected” error happens and follow our step-by-step guide to get back up and running.
fault 5080 in abb acs880 drive
If you’re staring at your ABB ACS880 control panel and see Fault 5080, you’re dealing with a cooling issue. In the world of high-performance drives, heat is the enemy, and Fault 5080 is the drive’s way of saying: “I can’t breathe.”
Officially, Fault 5080 is defined as “Cooling fan stuck or disconnected.” While it might seem like a minor nuisance, ignoring it usually leads to a Fault 5090 (Over-temperature), which will definitely shut down your production line.
Why is Fault 5080 Triggered?
The ACS880 uses a feedback loop to monitor the fan’s RPM. If the drive tells the fan to spin but doesn’t receive a “speed pulse” back from the Hall effect sensor within the fan, it trips the 5080 code. Common culprits include:
  • Physical Obstruction: Dust, debris, or a stray wire blocking the blades.
  • Loose Connections: Vibration can cause the fan plug to back out of its socket.
  • End of Life: The fan motor bearings have seized or the internal circuitry has failed.
  • Auxiliary Code : This specific sub-code usually confirms a main cooling fan issue.
Safety First: Before opening any drive cabinet, ensure the power is locked out/tagged out (LOTO). Wait at least 5 minutes for the DC bus capacitors to discharge.
Step-by-Step Troubleshooting
  1. Visual Inspection: Look at the fan located at the bottom (or top, depending on the frame size) of the drive. Is it spinning? Is there visible dust buildup? Sometimes a simple blast of compressed air can clear the blockage.
  2. Check the Connection: Locate the fan power and feedback connector. Unplug it, check for scorched pins or corrosion, and firmly re-seat it. A loose red or yellow wire is often the silent killer here.
  3. Test the Voltage: If the fan isn’t spinning, use a multimeter to check the voltage at the fan terminals. You should typically see 24V DC when the drive is commanded to run. No voltage? You might have a control board issue.
  4. Manual Spin Test: With the power OFF, try to spin the fan blades with a plastic tool. It should spin freely. If it feels “crunchy” or stiff, the bearings are shot.
  5. Check Parameters: Review parameter group 05 (Diagnostics). This will tell you the run time of the fan. ABB fans are rated for roughly 50,000 to 90,000 hours. If you’re past that, it’s time for a replacement.
When to Replace the Fan
If you have 24V going to the fan but it isn’t spinning, or if the feedback signal is missing despite the fan rotating, replace the fan assembly. Using an OEM ABB replacement fan is critical because the drive is calibrated to look for a specific pulse-per-revolution signal.
Pro-Tip: Preventive Maintenance
Don’t wait for a 5080 trip to take action. Include a “Fan Health Check” in your quarterly PMs. Listen for unusual whining noises—that’s the sound of a bearing about to fail. Keeping your filters clean will also extend the fan’s life by reducing the static pressure it has to work against.
