What is the meaning of fault Code 7991 and 8526 in siemens g120 drive?
2 Users
 sam
(@sam)
Eminent Member
[#20366]
How can i resolve the fault Code 7991 and 8526 in siemens g120 drive? i am facing this issue in my drive.
please suggest how i correct this fault
Fault codes 7991 and 8526 on a Siemens G120 drive usually occur together during commissioning.
  • A07991 (Motor Data Identification Active) means the drive is waiting to perform a motor ID run, often appearing after power-cycles.
  • A08526 (Profinet No Cyclic Connection) indicates the drive has no active communication with a PLC, often because the device name is not assigned
