A490 Incorrect temperature sensor setup warning in ABB ACS880 Drive
2 Users
How can resolve problem A490 Incorrect temperature sensor setup warning in ABB ACS880 Drive ?
Cause : Sensor type mismatch or Faulty wiring between an encoder interface module and the temperature sensor.
1. Check the settings of supervision source parameters 35.11 and 35.21 against 91.21 and 91.24.
2. Check the wiring of the sensor.
The auxiliary code (see the event log) identifies the interface module. (0 = Module 1, 1 = Module 2).
(@ultra7)
Active Member
@click2electro Where is that sensor located, to determine if it is that or if it is the module or the electronic card?
@ultra7 condition of fault - fault comes in running drive or this is a new programming
(@ultra7)
Active Member
@click2electro
ambient temperature fault even when vfd is off... room tempetrature is 82 degrees farenheit, but the display read 234 degrees farenheit. where are located these sensor, or if the problem is in a input module
@ultra7 share drive name plate pic
(@ultra7)
Active Member
@ultra7 pls share drive image also
