Electric Car Efficiency Converter
Convert between electric car efficiency units: mi/kWh, Wh/mi, Wh/km, kWh/100km, km/kWh, and MPGe. Includes conversion formulas, quick reference tables, and technical context.
EV Efficiency Unit Converter
Please enter a valid positive efficiency value.
Converted Efficiency Values
Miles per kWh (mi/kWh): 0.00
Kilometers per kWh (km/kWh): 0.00
Watt-hours per Mile (Wh/mi): 0.00
Watt-hours per Kilometer (Wh/km): 0.00
kWh per 100 Miles (kWh/100 mi): 0.00
kWh per 100 Kilometers (kWh/100 km): 0.00
EPA Fuel Economy Equivalent (MPGe): 0.00
Mathematical Conversion Formulas
Electric car efficiency units fall into two main metrics: Consumption (how much electricity is used over a set distance) and Economy (how far the car goes on a set amount of electricity). To convert between these units, use the base conversion constants below:
Constant: 1 Mile = 1.609344 KilometersConstant: 1 Gallon of Gasoline Equivalent = 33.705 kWh (EPA Standard)
1. Converting Consumption to Economy (Wh/mi to mi/kWh)
To convert energy used per mile to distance per kilowatt-hour, divide 1,000 by the consumption rating:
Miles per kWh (mi/kWh) = 1,000 ÷ Wh/miKilometers per kWh (km/kWh) = (1,000 ÷ Wh/km)
2. Converting Economy to Consumption (mi/kWh to Wh/mi)
To reverse the process and find energy consumed per mile or kilometer:
Wh/mi = 1,000 ÷ (mi/kWh)Wh/km = Wh/mi ÷ 1.609344
3. Converting to MPGe (Miles per Gallon Equivalent)
MPGe measures distance traveled relative to the chemical energy equivalent of one gallon of gasoline (33.705 kWh):
MPGe = mi/kWh × 33.705MPGe = 3,370.5 ÷ (kWh/100 mi)
EV Efficiency Benchmarks Quick Reference Table
This table compares common efficiency classes across the seven primary measurement standards, from highly streamlined commuter cars to large electric trucks.
Efficiency Tiermi/kWhkm/kWhWh/miWh/kmkWh/100kmMPGe
Excellent (e.g., Hyundai Ioniq 6)4.5 mi/kWh7.24 km/kWh222 Wh/mi138 Wh/km13.8 kWh/100km152 MPGe
Good (e.g., Tesla Model Y RWD)3.5 mi/kWh5.63 km/kWh286 Wh/mi178 Wh/km17.8 kWh/100km118 MPGe
Average (e.g., Audi Q8 e-tron)2.5 mi/kWh4.02 km/kWh400 Wh/mi249 Wh/km24.9 kWh/100km84 MPGe
Low (e.g., Rivian R1T / Hummer EV)2.0 mi/kWh3.22 km/kWh500 Wh/mi311 Wh/km31.1 kWh/100km67 MPGe
Understanding EV Efficiency Metrics
Gasoline cars are traditionally evaluated on economy (MPG). However, because electricity is sold in kilowatt-hours (kWh) and electric drivetrains operate with high thermodynamic efficiency, additional units are used to describe how a vehicle uses stored charge.
Consumption vs. Economy
  • Economy Units (mi/kWh, km/kWh, MPGe): Higher numbers indicate better efficiency. These tell you how far you can travel per unit of energy. Your dashboard often displays these units because they make calculating remaining range simple.
  • Consumption Units (Wh/mi, Wh/km, kWh/100km): Lower numbers indicate better efficiency. They represent the exact amount of grid energy required to move a set distance. These units are helpful for calculating long-term energy costs and home charging grid demand.
What is MPGe?
Established by the United States Environmental Protection Agency (EPA) in 2010, MPGe (Miles per Gallon Equivalent) allows consumers to compare alternative fuel vehicles to conventional gasoline models.
Based on standards defined by the National Institute of Standards and Technology (NIST), the chemical energy in one US gallon of gasoline matches 33.705 kilowatt-hours (kWh) of electricity. A car with a rating of 118 MPGe travels 118 miles on 33.705 kWh of electricity.
Variables Affecting Real-World EV Efficiency
Actual energy usage varies from EPA label figures based on real-world driving conditions:
  • Speed: Electric motor and drivetrain efficiency is high at lower speeds (urban traffic), but aerodynamic drag increases exponentially at highway speeds (above 65 mph or 105 km/h), causing consumption (Wh/mi) to rise.
  • Temperature: Cold weather slows battery chemical reaction times and requires cabin heating. Generating cabin heat in an EV uses high-voltage PTC heaters or heat pumps, drawing power directly from the traction battery and reducing driving range.
  • Regenerative Braking: City driving leverages regenerative braking to capture kinetic deceleration energy and return it to the battery cells, preserving overall efficiency.
Automotive Calculator List
Unit Conversion Calculators
Vehicle Loan Calculators
Wheels & Tires Calculators
