Calculate the cost to charge your electric vehicle (EV) based on battery capacity, target state of charge, electricity rates, and charging efficiency. Works with any currency.
EV Charging Cost Calculator
The EV Charging Cost Formulas
Calculating the true cost of charging an electric vehicle involves more than simply multiplying your battery size by your utility rate. The calculation must account for the power required to raise the state of charge, as well as the electrical efficiency losses of the charging hardware.
The step-by-step mathematical calculations used to find total cost are outlined below:
Step 1: Calculate Net Energy Required (kWh)
This determines the net electrical energy needed to fill the battery gap from your starting percentage to your target percentage:
Net Energy Required (kWh) = Battery Capacity (kWh) × [(Target % − Starting %) ÷ 100]
Step 2: Calculate Gross Energy Drawn from Grid (kWh)
Because charging systems generate heat and rely on cooling fans, they consume more power from your wall panel than actually reaches the battery cells. We adjust for this using the charging efficiency rate:
Gross Energy Drawn (kWh) = Net Energy Required (kWh) ÷ (Charging Efficiency % ÷ 100)
Step 3: Calculate Total Cost
Now, multiply the gross energy drawn by your local electricity rate per kilowatt-hour:
Total Cost = Gross Energy Drawn (kWh) × Electricity Rate per kWh
EV Charging Cost Reference Table
The table below presents estimated charging costs for popular electric vehicles under a typical scenario: filling the battery from 10% to 80% (a standard 70% charge window).
Note: These projections assume an electricity cost of 0.16 per kWh and a standard Level 2 home charging efficiency of 90%. This calculation is currency-independent and applies to any local currency denomination.
| Vehicle Model | Battery Size | Energy Added (Net) | Grid Drawn (Gross) | Est. Charging Cost |
| Tesla Model 3 / Y (RWD) | 60 kWh | 42.0 kWh | 46.7 kWh | 7.47 units |
| Volvo EX30 | 69 kWh | 48.3 kWh | 53.7 kWh | 8.59 units |
| Hyundai Ioniq 5 (Long Range) | 77.4 kWh | 54.2 kWh | 60.2 kWh | 9.63 units |
| Tesla Model S / X (Plaid) | 100 kWh | 70.0 kWh | 77.8 kWh | 12.45 units |
| Ford F-150 Lightning (Extended) | 131 kWh | 91.7 kWh | 101.9 kWh | 16.30 units |
Contextual Information & Cost Variables
To accurately predict and minimize your charging costs, it is useful to understand the physical variables that affect EV efficiency:
1. Why Charging Efficiency is Not 100%
When you plug in an electric vehicle, energy is drawn from the power grid as Alternating Current (AC). However, lithium-ion battery cells can only store Direct Current (DC). The vehicle’s onboard charger must convert the AC power to DC. This conversion process releases energy in the form of heat.
Additionally, the vehicle’s thermal management system must run coolant pumps or cabin fans to keep the battery cells at an optimal temperature. Standard Level 2 AC home chargers typically operate at 85% to 92% efficiency, meaning roughly 10% of the energy you pay for is lost to the environment.
2. Utility Rates: Flat vs. Time-of-Use (TOU)
Charging costs depend heavily on your local utility structure:
- Flat Rates: You pay the exact same price per kWh regardless of the time of day.
- Time-of-Use (TOU) Rates: Electricity rates fluctuate depending on overall grid demand. Off-peak times (typically overnight) are significantly cheaper than peak demand hours (typically late afternoon and early evening). Setting your EV to charge exclusively overnight can reduce charging costs.
3. Charger Levels and Efficiency
- Level 1 (120V AC Outlet): Typically the least efficient charging method (75% to 80% efficiency). Because charging takes so long, the car’s computer systems must remain active for extended periods, consuming overhead energy.
- Level 2 (240V AC Charger): The most common home charging method (88% to 92% efficiency). Higher voltage delivers faster charging with fewer relative conversion losses.
- DC Fast Charging (Direct High Voltage): Bypasses the vehicle’s onboard charger to feed DC power directly to the battery. While highly convenient for travel, commercial fast-charging rates are typically much higher than residential electricity rates.
Automotive Calculator List
- Carburetor CFM Calculator
- Convert lb/hr to cc/min
- Convert cc/min to lb/hr
- Engine Compression Ratio Calculator
- Engine Displacement Calculator
- Engine Horsepower Calculator
- Engine Torque Calculator
- Electric Vehicle Charging Cost Calculator
- Electric Vehicle Charging Time Calculator
- Electric Vehicle Fuel Savings Calculator
- Fuel Cost Calculator
- Fuel Injector Flow Rate Calculator
- Fuel Savings Calculator
- Gas Mileage Calculator
- Kilometers Per Liter Fuel Economy Calculator
- Liters Per 100 Kilometers Fuel Consumption Calculator
Unit Conversion Calculators
- Electric Car Efficiency Unit Conversions
- Fuel Economy Unit Conversions
- SAE to Metric Calculator
- Metric to Standard Calculator
- Speed Unit Conversions
- Torque Unit Conversions
Vehicle Loan Calculators
Wheels & Tires Calculators
