Kilometers per Liter Fuel Economy Calculator
Calculate your vehicle’s fuel economy in kilometers per liter (km/L). Supports odometer and trip distance inputs with immediate conversions to L/100km and MPG.
km/L Fuel Economy Calculator
Calculate using Odometer Readings
km
Distance traveled in kilometers.
liters
Amount of fuel (liters) added to fill the tank.
Please check your inputs. Current odometer must be greater than previous odometer.
Calculated Fuel Economy
0.00 km/L
Liters per 100 Kilometers (L/100km): 0.00 L/100km
Miles Per Gallon (US MPG): 0.00 MPG
Miles Per Gallon (UK Imperial MPG): 0.00 MPG
The Kilometers Per Liter Formula
Kilometers per liter (km/L) is a metric unit of fuel economy that represents the distance in kilometers a vehicle can travel on one liter of fuel. This metric is a direct indicator of fuel efficiency: the higher the number, the more efficient the vehicle.
The core mathematical calculation to find kilometers per liter is as follows:
Fuel Economy (km/L) = Distance Traveled (km) ÷ Fuel Consumed (Liters)
If you are tracking fuel economy manually using odometer readings rather than a trip computer, determine the distance traveled first:
Distance Traveled (km) = Current Odometer (km) − Previous Odometer (km)
Converting km/L to Other Common Units
While km/L is popular in many regions, converting to other systems like Liters per 100 Kilometers (L/100km) or Miles Per Gallon (MPG) can provide broader context:
  • Liters per 100 Kilometers (L/100km): L/100km = 100 ÷ km/L
  • Miles Per Gallon (US MPG): US MPG = km/L × 2.35215
  • Miles Per Gallon (UK Imperial MPG): UK MPG = km/L × 2.82481
Quick Reference Conversion Table
The reference table below showcases exact mathematical conversions from kilometers per liter (km/L) to standard metrics used globally, helping you understand your vehicle's performance across different scales.
Fuel Economy (km/L)Metric L/100kmMiles Per Gallon (US)Miles Per Gallon (UK)
5.0 km/L20.00 L/100km11.76 MPG14.12 MPG
8.0 km/L12.50 L/100km18.82 MPG22.60 MPG
10.0 km/L10.00 L/100km23.52 MPG28.25 MPG
12.0 km/L8.33 L/100km28.23 MPG33.90 MPG
15.0 km/L6.67 L/100km35.28 MPG42.37 MPG
18.0 km/L5.56 L/100km42.34 MPG50.85 MPG
20.0 km/L5.00 L/100km47.04 MPG56.50 MPG
25.0 km/L4.00 L/100km58.80 MPG70.62 MPG
Contextual Information: km/L vs. L/100km
Both km/L and L/100km are metric units, but they express efficiency differently:
  • km/L (Kilometers per Liter): This is a distance-per-fuel unit. It represents how far the vehicle goes on a fixed volume of fuel. It is highly intuitive because people naturally think of fuel capacity in terms of the distance it can cover. It is commonly used in Japan, India, South America, and parts of Europe.
  • L/100km (Liters per 100 Kilometers): This is a fuel-per-distance unit. It measures the volume of fuel required to drive a fixed distance. While less intuitive for calculating trip range, it makes calculating long-term fuel consumption or total fuel costs over distances much easier and is the standard metric across much of Europe and Canada.
Factors That Decrease Your km/L Efficiency
If your calculated km/L is lower than your vehicle's factory rating, a variety of mechanical and environmental factors may be the cause:
  • Tire Pressure: Under-inflated tires increase rolling resistance, forcing the engine to burn more fuel.
  • Air Filter and Spark Plugs: A dirty air filter restricts airflow, while worn spark plugs can cause incomplete combustion, both of which decrease efficiency.
  • Driving Habits: Rapid acceleration and high cruising speeds increase aerodynamic drag significantly, which lowers km/L ratings. Smooth acceleration and maintaining moderate, consistent speeds help preserve fuel.
Automotive Calculator List
Unit Conversion Calculators
Vehicle Loan Calculators
Wheels & Tires Calculators
