Calculate speedometer error and actual speed changes when upgrading or downsizing tires. Input standard tire specs to determine diameter changes and calibration offsets.
Speedometer Error Calculator
The Speedometer Error Formulas
A vehicle’s speedometer does not track actual ground speed. Instead, it measures the rotational speed of the transmission output shaft or wheel speed sensors and multiplies it by a pre-programmed constant based on factory tire circumference. When you change tire sizes, you alter the distance traveled per revolution, which introduces a speed calibration offset:
The mathematical operations used to compute diameter changes and speed differences are outlined below:
Step 1: Calculate Tire Diameter (Inches)
Standard P-metric tire sizes represent width in millimeters, aspect ratio as a percentage of width, and wheel size in inches. To compute total tire diameter:
Total Sidewall Height (mm) = Width × (Aspect Ratio ÷ 100) × 2Total Sidewall Height (inches) = Total Sidewall Height (mm) ÷ 25.4Tire Diameter = Total Sidewall Height (inches) + Wheel Diameter (inches)
Step 2: Calculate Speedometer Error and Actual Speed
The difference ratio between the old and new diameters determines the exact calibration error:
Speedometer Error Ratio = New Tire Diameter ÷ Original Tire DiameterActual Speed = Speedometer Reading × Speedometer Error RatioSpeedometer Error Percentage = (Speedometer Error Ratio − 1) × 100
Tire Size Calibration Reference Table
The table below provides estimated speedometer error offsets for various target speed readouts. It demonstrates how speed variance expands proportionally at higher travel velocities.
| Speedometer Reading | Actual Speed with +3.5% Error (Taller Tire) | Actual Speed with -3.5% Error (Shorter Tire) |
| 20 mph / kmh | 20.7 mph / kmh | 19.3 mph / kmh |
| 40 mph / kmh | 41.4 mph / kmh | 38.6 mph / kmh |
| 60 mph / kmh | 62.1 mph / kmh | 57.9 mph / kmh |
| 80 mph / kmh | 82.8 mph / kmh | 77.2 mph / kmh |
| 100 mph / kmh | 103.5 mph / kmh | 96.5 mph / kmh |
Practical Context: Speedometer Error and Tire Changes
Modifying your vehicle’s factory tire dimensions changes how the vehicle registers speed and mileage:
1. Taller Tires make the Speedometer Read Slow
If you mount a larger tire (e.g., upgrading from a 26-inch to a 28-inch overall diameter), each revolution of the wheel covers more distance. Because the vehicle’s computer still assumes the smaller original tire is turning, your actual speed over the ground will be faster than what is displayed on your speedometer. This creates a risk of unknowingly speeding.
2. Shorter Tires make the Speedometer Read Fast
If you mount a smaller tire, each wheel revolution covers less ground. Your speedometer will read faster than your actual vehicle speed. While less likely to result in a speeding ticket, this overstatement means you are traveling slower than you think.
3. Legal and Safety Standards (UN ECE Regulation 39)
Automotive manufacturers build in small safety margins to ensure compliance with international laws. Under UN ECE Regulation 39, speedometers are legally permitted to overestimate speed (by up to 10% + 4 km/h) to prevent drivers from accidentally speeding [7]. However, speedometers are legally prohibited from underestimating speed (reading slower than actual speed) with OEM tire setups.
4. The Odometer and Mileage Impact
Because the odometer tracks distance by counting wheel rotations, any speedometer error introduces a proportional odometer error:
- With taller tires, your odometer will record fewer miles than you actually traveled, potentially preserving vehicle resale value on paper but distorting fuel economy (MPG) calculations.
- With shorter tires, your odometer will rack up miles faster than you are actually driving them, prematurely shortening warranty windows.
Automotive Calculator List
- Carburetor CFM Calculator
- Convert lb/hr to cc/min
- Convert cc/min to lb/hr
- Engine Compression Ratio Calculator
- Engine Displacement Calculator
- Engine Horsepower Calculator
- Engine Torque Calculator
- Electric Vehicle Charging Cost Calculator
- Electric Vehicle Charging Time Calculator
- Electric Vehicle Fuel Savings Calculator
- Fuel Cost Calculator
- Fuel Injector Flow Rate Calculator
- Fuel Savings Calculator
- Gas Mileage Calculator
- Kilometers Per Liter Fuel Economy Calculator
- Liters Per 100 Kilometers Fuel Consumption Calculator
Unit Conversion Calculators
- Electric Car Efficiency Unit Conversions
- Fuel Economy Unit Conversions
- SAE to Metric Calculator
- Metric to Standard Calculator
- Speed Unit Conversions
- Torque Unit Conversions
Vehicle Loan Calculators
Wheels & Tires Calculators
