Metric to Standard Wrench Calculator | mm to SAE Size
Convert metric (mm) fastener and tool measurements to standard (SAE) fractional inches. Find the closest standard tool match and calculate fitment tolerances.
Metric to Standard Calculator
mm
Dropdown value will be ignored if you type a custom value.
Please make sure to choose or enter a valid measurement.
Fitment Comparison
Closest Standard Wrench
Exact Size Conversion: 0.0000″
Closest Mathematical Fraction: 0/0
Size Gap / Clearance: 0.00 mm
Fitment Rating: N/A
The Metric to Standard Formulas
Converting a metric fastener measurement in millimeters (mm) to a standard imperial (SAE) fractional size requires resolving the exact decimal equivalent first, and then mapping it to standard divisions of an inch (1/16, 1/32, 1/64):
Constant: 1 inch = Exactly 25.4 millimeters
1. Calculating Exact Decimal Inches
Divide the metric millimeter value by 25.4 to determine the exact decimal dimension in inches:
Decimal Inches = Metric Size (mm) ÷ 25.4
2. Determining the Closest Fraction
To find the closest common fraction, multiply the decimal by your target denominator (typically 16, 32, or 64) and round to the nearest whole integer. Then, reduce the fraction to its lowest terms:
Numerator = Round(Decimal Inches × Denominator)Closest Fraction = Numerator / Denominator
Metric to Standard Tool Conversion Chart
The table below details standard metric fastener sizes alongside their closest fractional SAE tool counterparts. It calculates the exact clearance gaps to evaluate if a substitute tool is safe to use under load.
Metric Size (mm)Exact Decimal InchesClosest SAE Wrench MatchFitment Gap (mm)Fitment Evaluation
8 mm0.3150"5/16" (0.3125")0.06 mmExcellent (Safe Match)
10 mm0.3937"3/8" (0.3750")0.48 mmPoor Fit (High risk of rounding)
11 mm0.4331"7/16" (0.4375")0.11 mmExcellent (Safe Match)
13 mm0.5118"1/2" (0.5000")0.30 mmCaution (Tight, low-torque only)
14 mm0.5512"9/16" (0.5625")0.29 mmCaution (Usable if necessary)
15 mm0.5906"5/8" (0.6250")0.88 mmPoor Fit (Do not use under load)
17 mm0.6693"11/16" (0.6875")0.46 mmPoor Fit (High risk of rounding)
19 mm0.7480"3/4" (0.7500")0.05 mmExcellent (Safe Match)
21 mm0.8268"13/16" (0.8125")0.36 mmCaution (Usable in emergency)
22 mm0.8661"7/8" (0.8750")0.23 mmCaution (Tight but usable)
Tuning Context: The Risk of Close Fit Tools
When working on automotive or machinery fasteners, using a tool that is "almost" the right size can result in rounded fastener heads, damaged sockets, or slip-related injuries. These key mechanical concepts explain the limits of tool substitution:
1. Clearance Tolerances Explained
Automotive mechanics classify the fit of a socket or open-end wrench based on the physical clearance gap between the tool flats and the fastener flats:
  • Excellent Fit (Under 0.15 mm): The tool has enough clearance to slide on easily, but not enough room to slip or tilt under high load. Using a 19mm wrench on a 3/4" bolt is highly safe because the gap is only 0.05 mm.
  • Caution Fit (0.15 mm to 0.38 mm): The wrench has noticeable play. This works in a pinch for hand-tight assembly but can slip or round the corners of rusted, seized, or high-torque fasteners.
  • Poor Fit (Over 0.38 mm): The tool has significant play. Using a 3/8" socket on a 10mm bolt head is highly risky because the 0.48 mm gap allows the socket to rotate over the corners of the bolt head, stripping the fastener.
2. "Standard" vs. "Metric" Tool Sets
Standard tools, often referred to as SAE (Society of Automotive Engineers), are sized in fractional increments of an inch and are common on domestic American machinery, older vehicles, and structural hardware. Metric tools are sized in exact millimeters and are the modern standard for import vehicles (Japanese, European), industrial electronics, and almost all vehicles built in recent decades.
3. Key Warning: 10mm vs. 3/8"
The most common tool swap in the garage is using a 3/8" wrench on a 10mm fastener. Because 10mm is equivalent to 0.3937", and 3/8" is equivalent to 0.3750", the 3/8" tool is actually too small to slide over a true 10mm bolt head. Conversely, attempting to use a 10mm socket on a 3/8" fastener presents a 0.48 mm gap. Under high torque, the 10mm socket will easily slip and round off the 3/8" bolt head. It is best to avoid swapping these two sizes.
Automotive Calculator List
Unit Conversion Calculators
Vehicle Loan Calculators
Wheels & Tires Calculators
