Speed Unit Converter
Convert speeds instantly between Miles per Hour (mph), Kilometers per Hour (km/h), Meters per Second (m/s), Knots, Feet per Second, and Mach.
Please enter a valid positive numerical value.
Converted Speed Measurements
Miles per Hour (mph): 0.00 mph
Kilometers per Hour (km/h): 0.00 km/h
Meters per Second (m/s): 0.00 m/s
Knots (Nautical MPH): 0.00 knots
Feet per Second (ft/s): 0.00 ft/s
Mach Number (Speed of Sound): Mach 0.00
The Speed Conversion Equations
Calculating speed conversions involves scaling values across different distance-to-time ratios. In scientific applications, the standard SI base unit of speed is Meters per Second (m/s). The standard mathematical relationships used to scale from this base unit are detailed below:
1. Converting Between m/s and km/h
Because there are 3,600 seconds in an hour and 1,000 meters in a kilometer, the relationship is a factor of 3.6:
Kilometers per Hour (km/h) = Meters per Second (m/s) × 3.6Meters per Second (m/s) = Kilometers per Hour (km/h) ÷ 3.6
2. Converting Between mph and km/h
This is the standard conversion used to scale speed limits between United States and international metric road signs:
Kilometers per Hour (km/h) = Miles per Hour (mph) × 1.609344Miles per Hour (mph) = Kilometers per Hour (km/h) ÷ 1.609344
3. Converting Knots to mph
A knot is defined as one nautical mile (which is equivalent to 1,852 meters or roughly 6,076 feet) per hour:
Miles per Hour (mph) = Knots × 1.15078Knots = Miles per Hour (mph) ÷ 1.15078
4. Calculating Mach Speed
The Mach number is the ratio of an object's speed to the local speed of sound. Under standard atmospheric conditions at sea level (15°C or 59°F), the speed of sound (Mach 1) is defined as:
Mach 1 = 340.29 m/s = 1,225.04 km/h = 761.2 mph = 661.5 knots
Speed Conversion Quick Reference Table
The table below provides quick reference comparisons for standard speed benchmarks across multiple measurement systems.
Speed Contextkm/hmphm/sKnotsMach
Average Walking Speed5.0 km/h3.1 mph1.4 m/s2.7 knotsMach 0.004
School Zone Speed Limit30.0 km/h18.6 mph8.3 m/s16.2 knotsMach 0.024
City Driving Speed50.0 km/h31.1 mph13.9 m/s27.0 knotsMach 0.041
Highway Speed Limit100.0 km/h62.1 mph27.8 m/s54.0 knotsMach 0.082
High-Speed Passenger Train300.0 km/h186.4 mph83.3 m/s162.0 knotsMach 0.245
Commercial Jet Airliner (Cruising)850.0 km/h528.2 mph236.1 m/s458.9 knotsMach 0.694
Standard Speed of Sound (Mach 1)1,225.0 km/h761.2 mph340.3 m/s661.5 knotsMach 1.000
Contextual Information: The History of Speed Units
Different industries and regions have developed distinct ways to measure speed based on historical needs and physical landmarks:
1. Why Are Marine Speeds Measured in "Knots"?
The term "knot" dates back to the 16th century when sailors measured the speed of their ships using a device called a "common log." This was a wooden board attached to a long rope that had physical knots tied at regular intervals of 47 feet and 3 inches.
The board was tossed into the water, and as the ship sailed away, a sailor would count how many knots passed through his hands in 28 seconds (measured with an hourglass). If 15 knots ran out, the ship was moving at "15 knots," which corresponds to 15 nautical miles per hour.
2. The Dynamic Nature of Mach Speed
Mach speed is unique because the speed of sound is not a fixed physical constant like the speed of light. Instead, sound is a mechanical vibration that travels by bouncing off molecules in a gas or liquid medium. Because molecules move faster and possess more kinetic energy in warmer air, sound travels faster through warm air and slower through cold air.
Consequently, at sea level on a standard day (15°C), Mach 1 is 761.2 mph. However, at a high altitude of 35,000 feet, where the air temperature drops to roughly -56°C, the speed of sound slows down to approximately 660 mph. An aircraft traveling at 660 mph at high altitude is moving at Mach 1, even though it would be subsonic at sea level.
Automotive Calculator List
Unit Conversion Calculators
Vehicle Loan Calculators
Wheels & Tires Calculators
