Torque Unit Converter | N-m, lb-ft, lb-in, & kg-m
Convert torque values across major engineering units including Newton-meters (N-m), Pound-feet (lb-ft), Pound-inches (lb-in), Kilogram-meters (kg-m), and Kilogram-centimeters (kg-cm).
Please enter a valid positive numerical value.
Converted Torque Measurements
Newton-meters (N-m): 0.00 N-m
Pound-feet (lb-ft): 0.00 lb-ft
Pound-inches (lb-in): 0.00 lb-in
Kilogram-meters (kg-m): 0.00 kg-m
Kilogram-centimeters (kg-cm): 0.00 kg-cm
The Torque Conversion Equations
Torque is a rotational twisting force calculated by multiplying the applied linear force by the distance of the lever arm. In metric SI systems, the standard unit of torque is the Newton-meter (N-m). In United States imperial and legacy systems, units like Pound-feet (lb-ft) and Pound-inches (lb-in) are standard. The mathematical conversion factors used to scale between these systems are detailed below:
1. Converting Newton-meters to Pound-feet
To convert from N-m to the standard US automotive unit (lb-ft), multiply by the force-distance constant:
Pound-feet (lb-ft) = Newton-meters (N-m) × 0.737562Newton-meters (N-m) = Pound-feet (lb-ft) ÷ 0.737562
2. Converting Newton-meters to Pound-inches
Pound-inches are typically used for light assembly and low-torque parameters (such as valve cover bolts or small electronics). One foot-pound contains 12 inch-pounds [6]:
Pound-inches (lb-in) = Newton-meters (N-m) × 8.85075Newton-meters (N-m) = Pound-inches (lb-in) ÷ 8.85075
3. Converting Metric Force Units (kg-m and kg-cm)
Older European and Japanese workshop manuals occasionally use kilogram-force units. These depend on standard gravity (9.80665 m/s²):
Newton-meters (N-m) = Kilogram-meters (kg-m) × 9.80665Newton-meters (N-m) = Kilogram-centimeters (kg-cm) × 0.0980665
Common Automotive Fastener Torque Benchmarks
The table below provides direct conversions for standard fastener categories, helping you verify settings when consulting manual specs written in different units.
Typical Fastener TypeMetric (N-m)Standard (lb-ft)Low-Torque (lb-in)Metric Mass (kg-m)
Small Valve Cover Bolt10.0 N-m7.4 lb-ft88.5 lb-in1.02 kg-m
Spark Plug (Aluminum Head)20.0 N-m14.8 lb-ft177.0 lb-in2.04 kg-m
Engine Oil Pan Drain Plug35.0 N-m25.8 lb-ft309.8 lb-in3.57 kg-m
Brake Caliper Mounting Bracket Bolt85.0 N-m62.7 lb-ft752.3 lb-in8.67 kg-m
Standard M12 Passenger Car Wheel Lug Nut110.0 N-m81.1 lb-ft973.6 lb-in11.22 kg-m
Heavy-Duty Suspension / Subframe Bolt150.0 N-m110.6 lb-ft1,327.6 lb-in15.30 kg-m
Large Axle Nut (Hub Assembly)250.0 N-m184.4 lb-ft2,212.7 lb-in25.49 kg-m
Engineering Context: Pound-feet vs. Foot-pounds
A frequent subject of debate among technicians and engineers is the distinction between "pound-feet" and "foot-pounds." While often used interchangeably in general workshop conversation, they technically describe different physical quantities:
1. Pound-feet (lb-ft) — The Vector of Torque
Pound-feet is the mathematically correct unit for describing torque (rotational twisting force). It is a vector quantity, representing a force of one pound applied at a perpendicular distance of one foot from a pivot point. In standard international documentation, torque is written in this force-distance format (e.g., Newton-meters or Pound-feet) to preserve the mechanical distinction.
2. Foot-pounds (ft-lb) — The Scalar of Work
Historically, "foot-pounds" describes mechanical work or energy (a scalar quantity). One foot-pound is the energy required to lift a one-pound object vertically by a distance of one foot. Because work is defined as force multiplied by distance in the direction of displacement, it shares the same base dimensions as torque but lacks rotational direction.
Why Torque Specification is Crucial
Applying the exact specified torque to an automotive fastener ensures the bolt is stretched slightly, acting like a tight metal spring. This elastic stretch creates a clamping force (preload) that keeps the assembly secure. Under-torquing a fastener can allow vibrations to gradually loosen the bolt. Over-torquing can stretch the bolt past its yield point, permanently weakening the metal, stripping the threads, or snapping the fastener completely.
Automotive Calculator List
Unit Conversion Calculators
Vehicle Loan Calculators
Wheels & Tires Calculators
