Calculate the estimated time to charge your electric vehicle (EV). Choose from battery size, starting and target charge, charging speeds, and efficiency.
EV Charging Time Calculator
The EV Charging Time Formulas
Calculating how long it takes to charge an electric vehicle depends on the battery size, the state of charge window you are trying to fill, and the speed of your charger after factoring in standard system efficiency losses.
The standard steps to calculate charging time are outlined below:
Step 1: Calculate Net Energy Needed (kWh)
Determine the total capacity in kilowatt-hours (kWh) needed to go from your starting charge level to your target level:
Net Energy Needed (kWh) = Battery Capacity (kWh) × [(Target % − Starting %) ÷ 100]
Step 2: Adjust Charging Power for System Efficiency (kW)
Onboard conversions and battery thermal management limit actual intake speed. This gives us the true power entering the battery pack:
Effective Charge Power (kW) = Charger Output (kW) × (Charging Efficiency % ÷ 100)
Step 3: Calculate Estimated Duration (Hours)
Divide the required energy by the adjusted charge power to find the raw hours, then convert the remaining decimal fraction to minutes:
Charging Time (Hours) = Net Energy Needed (kWh) ÷ Effective Charge Power (kW)Minutes = Remaining Decimal Portion × 60
EV Charging Time Reference Matrix
The table below provides a quick-reference estimate for charging a typical 75 kWh battery pack from 10% to 80% (adding 52.5 kWh of energy) across different common charging speeds and setups. Level 2 Three-Phase / Public AC
| Charger Type | Nominal Speed (kW) | Efficiency Rating | Effective Intake | Estimated Time |
| Level 1 Wall Outlet (US) | 2.3 kW | 85% | 1.95 kW | ~26 hours 55 minutes |
| Level 2 Low-Power AC | 3.7 kW | 90% | 3.33 kW | ~15 hours 45 minutes |
| Level 2 Standard Home AC | 7.4 kW | 90% | 6.66 kW | ~7 hours 53 minutes |
| 11.0 kW | 90% | 9.90 kW | ~5 hours 18 minutes | |
| Standard DC Fast Charger | 50.0 kW | 95% | 47.50 kW | ~1 hour 6 minutes |
| High-Power DC Fast Charger | 150.0 kW | 95% * | 142.50 kW | ~22 minutes * |
* Note: High-power DC Fast Chargers (>100 kW) cannot maintain their maximum advertised output continuously across the entire charge cycle. Read below to understand why actual times may vary.
Important Variables That Modify Charging Speed
While the linear calculations above are accurate for home AC chargers, real-world variables can alter charging times—especially when using public fast chargers.
1. The DC Fast Charging “Taper” Curve
When charging via DC Fast Charging (Level 3), the car does not charge at a constant rate. To protect the battery cells from heat stress and degradation, the vehicle’s battery management system (BMS) slows down the charge speed as the battery fills up.
This is commonly referred to as the charging taper. Typically, an EV will charge at high speed from 10% to roughly 65% or 80%. Past 80%, the speed drops significantly—often to AC speeds—making the final 20% take as long to charge as the first 80%. This is why EV manufacturers recommend unplugging at 80% SoC during road trips to maximize travel efficiency.
2. Onboard Charger Limitations (AC Charging)
When charging at home or at a public Level 2 charger, your speed is limited by your vehicle’s Onboard Charger (OBC). If your vehicle has an 11 kW OBC, but you plug into a public 22 kW AC station, your car will still only accept 11 kW. You cannot exceed the physical bottleneck of your vehicle’s AC conversion hardware.
3. External Temperature
Lithium-ion chemistry depends on chemical reactions that slow down in cold weather. If the battery pack is cold, the BMS will limit incoming power to prevent lithium plating, which can permanently damage the battery cells. Many modern electric cars feature a pre-conditioning system that pre-heats the battery on your way to a fast charger to ensure maximum charging speed.
Automotive Calculator List
- Carburetor CFM Calculator
- Convert lb/hr to cc/min
- Convert cc/min to lb/hr
- Engine Compression Ratio Calculator
- Engine Displacement Calculator
- Engine Horsepower Calculator
- Engine Torque Calculator
- Electric Vehicle Charging Cost Calculator
- Electric Vehicle Charging Time Calculator
- Electric Vehicle Fuel Savings Calculator
- Fuel Cost Calculator
- Fuel Injector Flow Rate Calculator
- Fuel Savings Calculator
- Gas Mileage Calculator
- Kilometers Per Liter Fuel Economy Calculator
- Liters Per 100 Kilometers Fuel Consumption Calculator
Unit Conversion Calculators
- Electric Car Efficiency Unit Conversions
- Fuel Economy Unit Conversions
- SAE to Metric Calculator
- Metric to Standard Calculator
- Speed Unit Conversions
- Torque Unit Conversions
Vehicle Loan Calculators
Wheels & Tires Calculators
