Fuel Cost Calculator
Calculate estimated fuel costs and fuel consumption for any trip or driving distance. Supports both Imperial (MPG) and Metric (L/100km) formats.
mi
MPG
/gal
Please make sure all fields contain valid positive numbers.
Estimated Trip Fuel Cost
$0.00
Fuel Needed: 0.00 gal
Average Cost per Unit Distance: $0.00
The Fuel Cost Formulas
Calculating the estimated cost of fuel for a road trip or commute depends on the distance traveled, the average fuel economy of the vehicle, and the unit price of fuel at the pump.
The mathematical operations used to determine trip costs differ by unit system:
1. Imperial Calculation Method (Miles / Gallons / MPG)
This system determines fuel consumption in gallons and total cost using standard domestic units:
Fuel Consumed (Gallons) = Trip Distance (Miles) ÷ Fuel Economy (MPG)Total Fuel Cost = Fuel Consumed (Gallons) × Fuel Price (per Gallon)
2. Metric Calculation Method (Kilometers / Liters / L/100km)
This standard international system determines fuel consumption based on volume consumed per 100 kilometers traveled:
Fuel Consumed (Liters) = [Trip Distance (km) ÷ 100] × Fuel Economy (L/100km)Total Fuel Cost = Fuel Consumed (Liters) × Fuel Price (per Liter)
Trip Fuel Cost Quick Reference Table
The reference matrix below showcases estimated trip costs for different distances across three common fuel economy profiles (a thirsty utility truck, an average sedan, and a highly efficient hybrid/compact car).
Note: These projections are calculated using a baseline fuel price of 3.50 per unit of volume (dollars, euros, pounds, or other local currencies).
Trip Distance20 MPG Cost (Lower Economy)30 MPG Cost (Average Economy)40 MPG Cost (High Economy)
50 miles8.75 units5.83 units4.38 units
100 miles17.50 units11.67 units8.75 units
250 miles43.75 units29.17 units21.88 units
500 miles87.50 units58.33 units43.75 units
1,000 miles175.00 units116.67 units87.50 units
Contextual Information & Real-World Variables
While trip calculations provide a reliable baseline, the actual amount of fuel burned over a given distance fluctuates based on driving environments and vehicle configurations:
1. City vs. Highway Fuel Economy
Vehicles perform differently depending on the driving environment. Standard window stickers display separate ratings for city and highway driving:
  • City Driving: Stop-and-go patterns force the engine to repeatedly work to pull the heavy vehicle weight from a standstill. This pattern uses significantly more fuel, especially in large internal combustion vehicles.
  • Highway Driving: Maintaining a steady speed in higher gears keeps engine rotational speed (RPM) low and constant. This is typically when an engine operates at its highest thermal efficiency, though high wind resistance at extreme highway speeds (above 70 mph or 113 km/h) can begin to lower efficiency.
2. Aerodynamics, Weight, and Accessories
  • Aerodynamic Drag: Roof racks, cargo carriers, or open windows disrupt airflow and increase drag, forcing the engine to burn more fuel to maintain speed.
  • Vehicle Weight: Every additional 100 pounds of cargo carried inside the cabin or trunk can decrease fuel economy by roughly 1%. Keep the trunk clean to maximize trip savings.
  • Auxiliary Loads (Air Conditioning): Running the air conditioning compressor draws energy directly from the engine pulley system, which can reduce fuel economy by up to 5% to 10% in hot weather.
3. Driving Style and Habits
The single largest variable behind real-world fuel economy is driver behavior. Rapid acceleration and aggressive braking waste fuel. Adopting a smoother, more predictive driving style—maintaining consistent speed and slowly accelerating away from stops—can significantly lower trip fuel costs over time.
Automotive Calculator List
Unit Conversion Calculators
Vehicle Loan Calculators
Wheels & Tires Calculators
