Calculate engine horsepower using torque and RPM, or estimate horsepower from vehicle weight, quarter-mile trap speed, and ET. Supports Imperial and Metric units.
Engine Horsepower Calculator
Formulas Used to Calculate Horsepower
Engine output can be measured directly on a dynamometer or estimated from acceleration metrics at a drag strip. The three formulas used in the calculator are detailed below:
1. Torque & RPM (The Mechanical Standard)
Horsepower measures the rate at which work is done. It is mathematically tied directly to rotational force (torque) and rotational speed (RPM). The standard formula is:
Horsepower (HP) = (Torque in lb-ft × RPM) ÷ 5,252
The constant 5,252 represents the relationship between the definition of one horsepower (33,000 foot-pounds per minute) and a circle's rotation (2π radians). Because of this constant, torque and horsepower curves on a standard dyno graph will always cross at exactly 5,252 RPM. [2]
2. Quarter-Mile Trap Speed Method
Trap speed is a highly reliable metric for calculating horsepower because aerodynamics and vehicle weight determine top speed on the track, bypassing wheel-spin variables. The calculator uses the established Fox formula:
Horsepower (HP) = Weight × (Trap Speed ÷ 234)³
Where weight is in pounds (including the driver) and speed is in MPH. This estimates peak wheel horsepower.
3. Quarter-Mile Elapsed Time (ET) Method
Elapsed time is heavily influenced by how well a car launches from a stop, but it can still provide a useful secondary average horsepower estimate. The calculator utilizes Riegel’s formula:
Horsepower (HP) = Weight ÷ (ET ÷ 5.825)³
Horsepower vs. Drag Strip ET Reference Table
This table displays the estimated flywheel/wheel horsepower required for various target quarter-mile elapsed times. The calculations are based on a standard 3,000 lbs (1,360 kg) vehicle using Riegel's ET formula:
| Target 1/4 Mile ET (sec) | Required Horsepower (HP) | Equivalent Power (kW) | Average Performance Description |
| 14.0 seconds | 216 HP | 161 kW | Modern Warm Hatchback / Daily Sedan |
| 13.0 seconds | 270 HP | 201 kW | Entry-Level Sports Car / Mildly Tuned I4 |
| 12.0 seconds | 343 HP | 256 kW | Performance Coupe / Modded Turbo |
| 11.0 seconds | 446 HP | 333 kW | Modern Supercar / Built Street Car |
| 10.0 seconds | 594 HP | 443 kW | Pro-Street drag build / Extreme Supercar |
| 9.0 seconds | 813 HP | 606 kW | Dedicated Track / Strip Dragster |
Contextual Information: Understanding Horsepower Concepts
What is Horsepower?
The term "horsepower" was created by Scottish engineer James Watt in the late 18th century to compare the output of steam engines to the pulling power of draft horses. Watt determined that a horse could turn a mill wheel 144 times in an hour, which equated to lifting 33,000 pounds by one foot in one minute. Today, one mechanical horsepower equals approximately 745.7 Watts.
Torque vs. Horsepower
A simple way to distinguish the two properties is: Torque is rotational force, while Horsepower is work over time.
- Torque: The physical twisting force that the engine crankshaft generates. Higher torque provides low-RPM acceleration, helping heavy vehicles pull away from a stop or climb hills.
- Horsepower: Determines how fast the engine can apply that torque. An engine with lower torque but higher RPM capability can still produce a high horsepower output because it performs work at a faster rate.
Crank Horsepower vs. Wheel Horsepower
When reviewing horsepower ratings, it is important to understand where the measurement is taken:
- Crank/Brake Horsepower (CHP/BHP): Measured directly at the engine crankshaft using an engine dynamometer. This is the official rating advertised by automotive manufacturers and excludes mechanical drag from the vehicle’s transmission, driveshaft, differentials, and tires.
- Wheel Horsepower (WHP): Measured at the drive wheels using a chassis dyno. Due to friction and rotational inertia within the drivetrain (known as parasitic loss), WHP is always lower than crank horsepower. Typically, front-wheel-drive vehicles experience a 10% to 15% loss, rear-wheel-drive vehicles experience a 15% to 18% loss, and all-wheel-drive systems can lose up to 20% to 25% of power between the crank and the tires.
Automotive Calculator List
- Carburetor CFM Calculator
- Convert lb/hr to cc/min
- Convert cc/min to lb/hr
- Engine Compression Ratio Calculator
- Engine Displacement Calculator
- Engine Horsepower Calculator
- Engine Torque Calculator
- Electric Vehicle Charging Cost Calculator
- Electric Vehicle Charging Time Calculator
- Electric Vehicle Fuel Savings Calculator
- Fuel Cost Calculator
- Fuel Injector Flow Rate Calculator
- Fuel Savings Calculator
- Gas Mileage Calculator
- Kilometers Per Liter Fuel Economy Calculator
- Liters Per 100 Kilometers Fuel Consumption Calculator
Unit Conversion Calculators
- Electric Car Efficiency Unit Conversions
- Fuel Economy Unit Conversions
- SAE to Metric Calculator
- Metric to Standard Calculator
- Speed Unit Conversions
- Torque Unit Conversions
Vehicle Loan Calculators
Wheels & Tires Calculators
